[mapserver-users] Mapserver & ECW in Linux
Gregor Mosheh
gregor at hostgis.com
Thu Oct 30 16:11:27 EDT 2008
Carlos Ruiz wrote:
> Yep, ECW and JPEG2000 appears using gdalinfo --formats
Good start. That brings us up to Mapserver. If you rebuilt it with GDAL
support and GDAL supports ECW, then Mapserver should support ECW
silently as any other raster format.
So exactly how is it not working?
Generating an error?
Generating emptiness?
Can you post relevant parts of your mapfile?
If it's a blank map, check your projection; I slap my forehead all the
time over that, requesting a map in latlon with data in UTM so my
request is millions of units away from the data.
Gregor Mosheh / Greg Allensworth BS, A+, Network+, Security+, Server+
System Administrator, Lead Programmer
HostGIS development & hosting services, http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
