[MAPSERVER-USERS] [Postgis] Intersection on requested data
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 31 12:12:05 EDT 2008
You need to understand the syntax of the DATA statement, which is not
pure SQL. It is:
[columntodraw] FROM [sourceofdata] USING UNIQUE [uniquekey] USING SRID=[srid]
columntodraw is always assumed to be a single word.
Write your data statement like this:
DATA "the_geom FROM (SELECT gid,ST_Intersection(kl_l.the_geom ,
ST_GeomFromText('POLYGON((165607 387820 , 165651 387813 , 165672
387759 , 165598 387800 , 165607 387820))' , 28992)) AS the_geom FROM
kl_l) AS SUBQUERY USING UNIQUE gid USING SRID=28992"
Note that result of the intersection is aliased as "the_geom" so that
it matches the columntodraw cited at the front, and the unique id is
included in the subquery and cited in the using unique. Also the SRID
is cited.
P.
