Re: [MAPSERVER-USERS] Highlighting query results
shurhen
shurhenv at mail.ru
Wed Sep 3 08:54:41 EDT 2008
Thank you, Steve!
I tried your way, but I have not got result - selected object still remains same as others.
I've added these lines in map-file but there are no results:
QUERYMAP
COLOR 0 0 255
STATUS ON
STYLE HILITE
END
What I've missed?
2BrainDrain: Thank you, I'll try and your way too.
Steve Lime wrote:
> MapServer supports what's called a query map. It basically replaces the
> color of the top-most
> style for a layer with one defined in the query map object (default is
> yellow). Typically in MapScript
> you'd do:
> a_layer.queryByAttributes(m_map, null, a_query, 1);
> img = m_map.drawQuery();
> You can of course get fancier and step through the result set by hand but
> I wouldn't recommend
> starting that way.
> Steve
