[mapserver-users] Brand New User
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Sep 3 17:28:20 EDT 2008
Again, MS4W does have its own mailing list so it would be better to use
that for configuration questions.
You could download an MS4W add-on package from the MS4W downloads page,
extract it at the same drive root, and look in ms4w/httpd.d/ again.
Once more, please move this discussion to the MS4W mailing list. thank you.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
Bob Pawley wrote:
> Thanks Jeff
> "...a new httpd_*.conf file should [also] be added to
> /ms4w/httpd.d/httpd_*.conf."
> Does this mean that these files are installed when the Web application (in
> this case Workshop-5) is extracted into ms4w/app or is this a file which I
> need to generate?? At the moment I can't find any such file under
> ms4w/httpd.
> If I need to generate the file is there an example around??
> Bob
> ----- Original Message ----- From: "Jeff McKenna"
> <jmckenna at gatewaygeomatics.com>
> To: <mapserver-users at lists.osgeo.org>
> Sent: Wednesday, September 03, 2008 10:57 AM
> Subject: Re: [mapserver-users] Brand New User
>> Hello,
>> Welcome into the foray :) I have some comments below inline:
>> Bob Pawley wrote:
>>> Hi
>>> This is my first foray into servers et al. I have a couple of
>>> questions for anyone who wishes to answer.
>>> I have downloaded ms4w (Windows install package) installed it and
>>> tested for working by asking for version number through command line
>>> as well as an HTTP request to mapserver.exe. Both were successful.
>> great!
>>> Eventually I want to access a Postgis database.
>>> I have also downloaded Workshp -5 and installed it under
>>> ms4w/Apache/htdocs
>> MS4W is designed to have all of the add-on applications live in
>> /ms4w/apps/.
>> Also, to quote from the MS4W README:
>> /ms4w/httpd.d/httpd_*.conf. (The /httpd.d/ directory contains Apache
>> configuration files that define which files on your computer/server
>> are Web-accessible. For each Web application that you install, a new
>> configuration file [will need to be created]."
>> Once you have created the new Apache alias that way, then you should
>> restart Apache (run /ms4w/restart-apache.bat from the commandline) and
>> goto 127.0.0.1/youralias
>>> My first challenge comes with setting the url and pathways in
>>> Workshop-5 Map File and html pages.
>>> I want to set the system up as a local app until I get it running.
>>> 1. Can Someone give me a url and pathway example of a local setup?
>>> (I've attempted variations on localhost and localhost.localdomain
>>> with no success).
>> see above
>>> 2. Since Map File appears to be project oriented is this a file that
>>> I need to generate in order to access Poistgis?
>> Yes you will need to generate a custom mapfile. Here are some
>> resources for you:
>> - Vector Data Reference guide, for PostGIS:
>> http://mapserver.gis.umn.edu/docs/reference/vector_data/postgis
>> - testing your .map file with the shp2img.exe utility (after executing
>> /ms4w/setenv.bat at the commandline):
>> http://mapserver.gis.umn.edu/docs/reference/utilityreference/shp2img
>> Also, please note that MS4W does have its own mailing list for
>> configuration issues (join at:
>> http://lists.maptools.org/mailman/listinfo/ms4w-users_
>> have fun.
>> Jeff McKenna
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
