[mapserver-users] ArcSDE 9.2 support
Liz Godwin
godwin.liz at gmail.com
Wed Sep 3 17:43:54 EDT 2008
Hi Jeff,
I should have added that part. On Windows with MS4W, I DO use the
CONNECTIONTYPE PLUGIN configuration with the plugin. It renders properly
the points, but not the labels. On Linux (the layer snippit I included) I
get a server failure, no rendering at all.
Liz
On Wed, Sep 3, 2008 at 1:29 PM, Jeff McKenna
<jmckenna at gatewaygeomatics.com>wrote:
> My only comment is that the SDE plugins in MS4W are quite old
> (~2007/09/17), but Howard would have to speak to whether that could be
> an issue. Liz, what happens when u try CONNECTIONTYPE PLUGIN (as
> instructed in the MS4W readme[1])?
> [1] http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> Liz Godwin wrote:
>> Hey folks,
>> I noticed there was a closed bug on this issue, but I am still having
>> problems connecting to SDE with Unicade enabled.
>> http://trac.osgeo.org/mapserver/ticket/2225
>> We have the most recent version of Mapserver (5.2) and all the libraries
>> are updated, and it still does not work. On windows with MS4W 2.2.9 and the
>> SDE 9.2 plugin, I get the attached image (unicode.png). On Linux, I get an
>> Internal Server Error (Premature End of Script Error in Apache log) and no
>> debug information is written to the mapserver log.
>> Is there something to configure that we're missing to support this change?
>> We have a workaround in mind, but it's a lot of work to reload all the
>> data to remove unicode.
>> LAYER # on Linux
>> DEBUG 5
>> NAME myname
>> TYPE point
>> STATUS DEFAULT
>> CONNECTIONTYPE SDE
>> CONNECTION "host,port:xxxx,instance,user,pass"
>> DATA "MARTVECTOR.CUL_NSF_POP_PLACE,SHAPE"
>> LABELITEM "xxxx"
>> CLASS
>> NAME "Points"
>> SYMBOL 'tent'
>> COLOR 255 0 0
>> OUTLINECOLOR 125 125 125
>> SIZE 10
>> LABEL
>> COLOR 255 0 0
>> FONT arial
>> TYPE truetype
>> size 10
>> END
>> END
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080903/2eba50cb/attachment.html
