[mapserver-users] High CPU
Steve White
steve at online-archaeology.co.uk
Sun Sep 7 16:32:41 EDT 2008
Ed -
The reason I feel edgy is because I have other hosted .NET applications on
the same box.
I discovered from my tests that another process (CSRSS.exe) is also using
excessive CPU (about 40%), so it's not all MapServer, so I'm going to set up
some auto tests scripts to find out what kind of a ceiling I have and see if
I can pull down CSRSS.exe a bit.
Cheers,
Steve
Sent: 07 September 2008 13:48
To: Steve White; Paul Ramsey
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] High CPU
Steve -
Would you prefer your CPU was sitting idle? Keeping the CPU busy is a good
thing, isn't it? It means your network, disk, and other resources are not
preventing your CPU from working at full capacity.
What makes you feel that running your CPU at 100% capacity is a bad thing?
- Ed
Ed McNierney
205 Indian Hill Road
Groton, MA 01450
ed at mcnierney.com
+1 (978) 761-0049
On 9/7/08 4:20 AM, "Steve White" <steve at online-archaeology.co.uk> wrote:
The problem is that CPU shoots to 100% while tiles are being generated from
a remote WMS call.
The shp2img dump was taken directly on the server but the problem occurs
when I send remote WMS requests to the server.
I'm starting to think that 640MB RAM isn't enough and I should probably bump
it up to 1GB.
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at cleverelephant.ca]
Sent: 07 September 2008 06:07
To: Steve White
It took 0.3s to run to completion, what's the problem precisely?
P.
On Sat, Sep 6, 2008 at 1:35 PM, Steve White
> Thanks Jeff -
> - I upgraded to MS4w 2.2.9
> - I ran shptree.exe and produced the index file
> - My results of shp2img.exe are below
> - I don't think any projections-on-the-fly are occurring
> Shp2img dump:
> msDrawMap(): Layer 0 (OA), 0.015s
> msDrawMap(): Drawing Label Cache, 0.000s
> msDrawMap() total time: 0.015s
> SaveImage() total time: 0.297s
> msFreeMap(): freeing map at 0144B498.
> I'm still getting very high CPU usage with just one active session, so
> there's no way I can go into production till this is resolved.
> Any other things I can look at?
> Cheers,
> Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080907/a7090f39/attachment.html
