[mapserver-users] Arabic labeling problem again?!!!
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Sep 9 10:56:00 EDT 2008
Hello Saka,
There are a lot of pieces that you have to get working together to get
this to work:
1) mapserver 5.2 MUST be built with fribidi2 support. I beleieve this is
also designated as version fribidi-0.19.1
2) A typetype font file that contains the shape gliphs that you might
need along with the characters that you need to display.
3) And I'm sure this works with UTF-8, but unsure about other encodings.
4) your data converted to UTF-8 if it is in some other encoding
5) and finally you mapfile label definition which specifies an encoding
of utf-8.
You might get other variations of this to work, I would be interested in
hearing your reports of you can get others to work. I have sucessfully
gotten the above to work.
Best regards,
-Stephen Woodbridge
Saka Royban wrote:
> Hi all.
> I've asked this problem in MS4W mailing list but no success. it sounds
> it originally relates to mapserver
> According to what History.txt for MS4W2.2.8 says, problem for arabic
> and hebrew languages has been solved by using UTF8. But i couldn't get a
> good result.
> In fact, UTF8 doesn't show letters correctly (just some symbols). i have
> tried lots of fonts but the same result.
> in current version, the problem of joining letters have been solved
> because i can get result using 'ISO8859-6' encoding which is for arabic
> but now this encoding changes some of letters with each other.
> In last version, 'Windows-1256' encoding (for arabic) worked well for
> showing letters just they were separate not joint. but in cuurent
> versions this encoding just shows some symbols.
> I'm confused. maybe i should setup sth which i don't do or i don't know
> sth else.
> that would be my appreciate to help me because it is really a need. Maps
> without labels have less usage.
> Thanks in advance
> (See attachments)
> My Mapfile:
> LABEL
> TYPE TrueType
> FONT timesnewromans
> ENCODING 'windows-1256'
> SIZE 12
> END
> mapserver-users at lists.osgeo.org
