[mapserver-users] WCS 1.1.0 support in MapServer 5.2?
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Sep 11 12:13:39 EDT 2008
Committed in r7906.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Glenn
Waldron
Sent: 11 September, 2008 12:02 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WCS 1.1.0 support in MapServer
5.2?
Glenn,
I would suggest ensuring that -DUSE_LIBXML2 appears in
the compile lines
as mapserver is building. I would suggest doing a make
clean after the
configure. I would suggest ensuring that you are really
using the newly
installed executable after rebuilding and installing it.
It is *almost* certain you have just not done a clean
enough rebuild and
reinstall with the new options.
Frank,
You were correct; I was copying mapserv to the wrong place.
On a related note, I found what I believe to be a bug:
mapwcs11.c, line 1149
There should be no comma at the end of the line. The
msIO_fprintf statement results in junk; removing the comma fixes the
problem.
Glenn
Glenn Waldron : Pelican Mapping : http://pelicanmapping.com :
+1.703.652.4791
