[mapserver-users] Different color for each row and it'schild
Fawcett, David
David.Fawcett at state.mn.us
Mon Sep 15 16:52:20 EDT 2008
It could just be the documentation, but it looks like the attribute
binding may not work at the class level. Wrap your styling info in a
STYLE and see if that works.
http://mapserver.gis.umn.edu/docs/reference/mapfile/style
CLASS
NAME 'crews'
# MAXSCALE 250000
STYLE
COLOR [symcolor]
BACKGROUNDCOLOR 255 255 255
OUTLINECOLOR 255 255 255
SYMBOL 'crewsymbol'
SIZE 25
END # end of style
LABEL
COLOR [symcolor]
TYPE TRUETYPE
FONT arial
SIZE 9
MAXSIZE 9
MINSIZE 8
ANTIALIAS TRUE
POSITION UC
PARTIALS FALSE
FORCE TRUE
END
END
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lee Keel
Sent: Monday, September 15, 2008 3:43 PM
To: Steve Lime; mapserver-users at lists.osgeo.org; David Fawcett
Subject: RE: [mapserver-users] Different color for each row and
it'schild
Sorry....
LAYER
NAME "crews"
GROUP "data"
CONNECTIONTYPE postgis
CONNECTION "db"
DATA "the_geom from (select prikey, the_geom, crewname || ' ' ||
last_name as name, color as symcolor from crews) as foo using srid=2236,
using unique prikey"
PROCESSING "CLOSE_CONNECTION=DEFER"
METADATA
"wms_title" "Crews"
"wms_group_title" "data"
"wms_layer_title" "Crews"
END
PROJECTION
"init=epsg:2236"
END
STATUS ON
TYPE POINT
# MAXSCALE 250000
LABELMAXSCALE 250000
LABELITEM "name"
CLASS
NAME 'crews'
# MAXSCALE 250000
COLOR [symcolor]
SYMBOL 'crewsymbol'
SIZE 25
LABEL
COLOR [symcolor]
TYPE TRUETYPE
FONT arial
SIZE 9
MAXSIZE 9
MINSIZE 8
ANTIALIAS TRUE
POSITION UC
PARTIALS FALSE
FORCE TRUE
END
END
END
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Monday, September 15, 2008 3:39 PM
To: mapserver-users at lists.osgeo.org; David Fawcett; Lee Keel
it'schild
Sharing the snippet of mapfile would help...
Steve
>>> On 9/15/2008 at 3:35 PM, in message
<944DCD961F4CD649BCEBB52E3C929F650270805A at usd-am-xch-01.am.trimblecorp.n
et>,
"Lee Keel" <lee_keel at trimble.com> wrote:
> David,
> Thanks for the reply, but I can't seem to get this to work. When I
> change my mapfile to use this new attribute column, that layer (and
most
> all my others) go away and I get this as the response in FF:
> <HTML>
> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
> <!-- MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT
> =SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS
> =GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> <BODY BGCOLOR="#FFFFFF">
> getSymbol(): Symbol definition error. Parsing error near
> (symcolor):(line 1684)
> </BODY></HTML>
> I added the column to my query and add that column name, in [] to my
> class item. Is there something that I am missing?
> Please note: I have looked at the
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19/ page and I
think
> I understand what is required. But now I am thinking that this is not
> in MS4W 2.2.6. Can anyone answer if that is the case? And if so, is
> there another solution like this around that version?
> Thanks in advance,
> Lee
> From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> Sent: Monday, September 15, 2008 9:51 AM
> To: Lee Keel; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] Different color for each row and it's
> child
> I would suggest creating a column in table A to store a color value
and
> pre-populating it. You would want to store the RGB triplet (e.g. '255
0
> 0'). I assume that you could have some sort of a stored proc that
gets
> triggered when a new record gets added.
> Using the new attribute binding in MapServer 5, you could then just
set
> the feature color by specifying the column name in the style in your
map
> file layer definition.
> Something like:
> STYLE
> COLOR [myColorColumn]
> OUTLINECOLOR 0 0 0
> END
> As soon as someone kicks the MapServer site server and it restarts, I
> suggest looking at the map file reference document under style.
> Also, make sure that your color column is specified in the query in
your
> data statement.
> David.
> From: mapserver-users-bounces at lists.osgeo.org
> Sent: Monday, September 15, 2008 9:33 AM
> Subject: [mapserver-users] Different color for each row and it's
> child
> I had a client request something that sounds really cool, but I
don't
> know how to do it (or if it is even possible in mapserver).
> First, my setup:
> I am running MS4W 2.6 on windows xp against postgis 8.2
database. I
> have table A that has anywhere from 4 to 35 rows. And table B which
> could have several hundred rows each relating back to
one
> of the rows from table A.
> For Example:
> TableA
> ID Name
> 1 t
> 2 t2
> 3 t3
> 4 t4
> TableB
> ID ta_id Value
> 1 1 something
> 2 1 something else
> 3 1 test
> 4 2 foo
> 5 2 bar
> 6 3 done
> Now my problem:
> The client would like to see all the rows rendered from tableA
as
> different colors. These colors can be random, it doesn't matter.
On
> top of this, they want to see all the associated rows in tableB as the
> same color as their parent from tableA.
> Can I add a column to tableA and use that as a value in the
mapfile
> for the style? And if so, how?
> I would greatly appreciate any help that anyone can provide.
> Thanks in advance,
> Lee
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
