[MAPSERVER-USERS] Debian Oracle10g OCI
Umberto Nicoletti
umberto.nicoletti at gmail.com
Tue Sep 16 05:29:50 EDT 2008
Revert configure to the previous oraclespatial setting and try:
export ORACLE_HOME=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server
before configure.
Umberto
2008/9/16 <dzizes451 at gmail.com>:
> Now I get:
> checking if OracleSpatial support requested... yes, user supplied
> ORACLE_HOME
> configure: error: Oracle Spatial: libclntsh.so not found.
> I enclose the config.log.
> Michał
> 2008/9/16 Umberto Nicoletti <umberto.nicoletti at gmail.com>
>> try:
>> -with-oraclespatial=/usr/lib/oracle/xe/app/oracle/product/10.2.0
>> otherwise post the config.log file.
>> Umberto
>> > Thanks for the tip!
>> > The Makefile looks like:
>> > -------------- Compiler Info -------------
>> > C compiler: gcc -O2 -fPIC -Wall
>> > C++ compiler: g++ -O2 -fPIC -Wall
>> > Debug:
>> > Generic NINT:
>> > -------------- Renderer Settings ---------
>> > zlib support: -DUSE_ZLIB
>> > png support:
>> > palette rgba png support:
>> > jpeg support:
>> > iconv support: -DUSE_ICONV
>> > AGG support:
>> > AGG Freetype support:
>> > Ming(flash) support:
>> > PDFLib support:
>> > -------------- Support Libraries ---------
>> > Proj.4 support: -DUSE_PROJ
>> > Libxml2 support:
>> > FriBidi support:
>> > Curl support: -DUSE_CURL
>> > FastCGI support:
>> > Threading support: -DUSE_THREAD
>> > GEOS support:
>> > -------------- Data Format Drivers -------
>> > native tiff support:
>> > PostGIS support:
>> > EPPL7 support: -DUSE_EPPL
>> > ArcSDE support:
>> > OGR support: -DUSE_OGR
>> > GDAL support: -DUSE_GDAL
>> > Oracle Spatial support: -DUSE_ORACLESPATIAL
>> > -------------- OGC Services --------------
>> > WMS Server: -DUSE_WMS_SVR
>> > WMS Client: -DUSE_WMS_LYR
>> > WFS Server:
>> > WFS Client: -DUSE_WMS_LYR
>> > WCS Server:
>> > SOS Server:
>> > -------------- MapScript -----------------
>> > PHP MapScript: no
>> > the make command throws the following error:
>> > warning: libnnz10.so, needed by
>> > /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so,
>> > not
>> > found (try using -rpath or -rpath-link)
>> > /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so:
>> > undefined reference to `nztSearchNZDefault'
>> > undefined reference to `nzosCipherSpecToStr'
>> > undefined reference to `nztwOpenWallet'
>> > undefined reference to `A_X931RandomInit'
>> > ends with
>> > collect2: ld returned 1 exit status
>> > make: *** [shp2img] Error 1
>> > any ideas!
>> > Michał
>> >> Usign tiff AND gdal is not recommended, you'd better try these options:
>> >> ./configure
>> >> -with-oraclespatial=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server
>> >> -with-proj -with-wfsclient -with-wmsclient -with-gdal -with-ogr
>> >> -with-threads -with-freetype -without-tiff -with-FastCGI
>> >> as for the expat error:
>> >> sudo apt-get install libexpat1 libexpat1-dev
>> >> Umberto
>> >> > Hi again,
>> >> > I've tried to compile mapserv executable with:
>> >> > ./configure
>> >> > -with-threads -with-freetype -with-tiff -with-FastCGI
>> >> > and I receive this error:
>> >> > /usr/bin/ld: cannot find -lexpat
>> >> > Does anyone know what is wrong?
>> >> > Michał
>> >> > On Mon, Sep 15, 2008 at 3:16 PM, Dan Little <danlittle at yahoo.com>
>> >> > wrote:
>> >> >> Umberto is right, for Mapserver to connect to Oracle you need to
>> >> >> specify
>> >> >> that capability at compile time. But for you ge tthat far I think
>> >> >> you
>> >> >> need
>> >> >> to make sure that some of the basics work.
>> >> >> Also, if you cannot connect to Oracle via SQL*Plus (assuming the
>> >> >> binary
>> >> >> is
>> >> >> installed) you have other problems including but not limited to:
>> >> >> - needing to set the LD_LIBRARY_PATH to include all the libraries.
>> >> >> This
>> >> >> may also need to be done in Apache while running mapserver to access
>> >> >> Oracle.
>> >> >> - needing to configure your TNSNAMES file.
>> >> >> - check firewall setting in order to make sure you can connect on
>> >> >> 1521
>> >> >> (or
>> >> >> whatever port you are using for Oracle).
>> >> >> Generally, when running an Oracle layer, you want to try the
>> >> >> following
>> >> >> diagnostic steps:
>> >> >> 1) Use SQL Developer to connect to the database (it has it's own
>> >> >> drivers
>> >> >> built in, so there's no software dependency issues). This will
>> >> >> resolve
>> >> >> whether or not the databas is working.
>> >> >> 2) On the machine, try connecting with SQL Plus. This will
>> >> >> determine
>> >> >> whether or not you have your client configured correctly. Do not
>> >> >> move
>> >> >> on
>> >> >> until this works.
>> >> >> 3) Try and re-compile Mapserver with Oracle Spatial. At the end of
>> >> >> the
>> >> >> ./configure script there is an output screen, ensure that you see
>> >> >> Oracle is
>> >> >> turned on, otherwise scroll up in the screen and see what's missing.
>> >> >> ----- Original Message ----
>> >> >> > From: Umberto Nicoletti <umberto.nicoletti at gmail.com>
>> >> >> > To: dzizes <dzizes451 at gmail.com>
>> >> >> > Cc: mapserver-users at lists.osgeo.org
>> >> >> > Sent: Monday, September 15, 2008 7:45:48 AM
>> >> >> > Subject: Re: [MAPSERVER-USERS] Debian Oracle10g OCI
>> >> >> > You have to recompile mapserver with the:
>> >> >> > --with-oraclespatial=[path to oracle home]
>> >> >> > option. That's all that is needed to enable oracle spatial support
>> >> >> > in
>> >> >> > mapserver.
>> >> >> > HTH,
>> >> >> > Umberto
>> >> >> > On Mon, Sep 15, 2008 at 2:05 PM, dzizes wrote:
>> >> >> > > Hi,
>> >> >> > > I've installed mapserver on Debian (lenny distribution). I've
>> >> >> > > managed
>> >> >> > > to
>> >> >> > > create mapfile based on shp data and successfully send a wms
>> >> >> > > request
>> >> >> > > to get
>> >> >> > > a map. I seems that mapserver works fine.
>> >> >> > > I've also installed oracle-ex and I can connect to my Oracle via
>> >> >> > > sqlplus.
>> >> >> > > However, when I request wms (to a map file pointing to
>> >> >> > > Oracle10g) I
>> >> >> > > receive
>> >> >> > > the following:
>> >> >> > > msDrawMap(): Image handling error. Failed to draw layer named
>> >> >> > > 'test'.
>> >> >> > > msOracleSpatialLayerOpen(): OracleSpatial error. OracleSpatial
>> >> >> > > is
>> >> >> > > not
>> >> >> > > supported
>> >> >> > > I've found that I need OCI installed and configured properly,
>> >> >> > > but
>> >> >> > > there is
>> >> >> > > no clear tutorial.
>> >> >> > > Please provide me a some step by step guide.
>> >> >> > > Greets,
>> >> >> > > Michal
>> >> >> > > View this message in context:
>> >> >> > http://www.nabble.com/Debian-Oracle10g-OCI-tp19491636p19491636.html
>> >> >> > > Sent from the Mapserver - User mailing list archive at
>> >> >> > > Nabble.com.
>> >> >> > > _______________________________________________
>> >> >> > > mapserver-users mailing list
>> >> >> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
