[mapserver-users] Using Fast CGI with MapServer to alleviatepoor
performance
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 19 13:52:39 EDT 2008
Has anyone thought of using SQLite internally in mapserver for say
storing the EPSG file in an indexed table for faster access. We could
have a utility that would read the epsg text file and create the table
for maintenance purposes.
SQLite has some other interesting possibilities if you combine it with
SpatiaLite which has most all of PostGIS support so you could have the
OpenSource Equivalent GeoDatabase, but that probably another thread.
-Steve W
Guillaume Sueur wrote:
> doesn't mapserver have to scan the whole epsg file to find the matching
> epsg - proj pair ?
> Steve Lime a écrit :
>> This shouldn't be the case, there are tests in the main API code to test
>> projections of the map
>> against layers to avoid this. I suspect it's projection related
>> though...
>> Steve
>>>>> On 9/19/2008 at 11:19 AM, in message
>> <48D3D0F9.5040904 at neogeo-online.net>,
>> Guillaume Sueur <guillaume.sueur at neogeo-online.net> wrote:
>>> I guess that wms makes a reprojection job as the request comes with
>> an
>>> EPSG code and the map projection is set by a proj string. Even if
>> they
>>> are equivalent, can MapServer know that and forget about reprojection
>>> The cgi is rather straight forward as no EPSG is required. As the
>> layers
>>> don't have PROJECTION blocks, they are drawn straight forward.
>>> my 2 cents.
>>> Guillaume
>>> Christopher Schmidt a écrit :
>>>> On Fri, Sep 19, 2008 at 03:34:42PM +0100, John Westwood wrote:
>>>>> Hi Everybody,
>>>>> I am attaching a cut down version of my html, javascript and map
>> files. On
>>> our server the EmbeddedMap.js lives in the OpenLayers directory and
>> is used
>>> by gbhgis_openlayers.html.
>>>>> The test address http://148.197.8.119/gbhgis_openlayers.html . This
>> is just
>>> a test server so please don't tell the whole World about it! :)
>>>>> There are four layers, 2 x raster (europe 1940s, WMS and MapServer)
>> and 2 x
>>> vector / raster (Digital Chart of the World, WMS and MapServer) .
>>>> Okay, so to cut OpenLayers out of the loop:
>> http://148.197.8.119/cgi-bin/mapserv?map=/data/map-files/gbhgis.map&service=WMS&L
>> AYERS=europe&FORMAT=image%2Fpng&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=ap
>> plication%2Fvnd.ogc.se_inimage&SRS=epsg%3A3034&BBOX=2097152,2097152,4194304,419
>>> 4304&WIDTH=256&HEIGHT=256
>> http://148.197.8.119/cgi-bin/mapserv?map=/data/map-files/gbhgis.map&layers=europ
>> e&format=image%2Fpng&mode=map&map_imagetype=png&mapext=2097152+2097152+4194304+41
>> 94304&imgext=2097152+2097152+4194304+4194304&map_size=256+256&imgx=128&imgy=128&im
>>> gxy=256+256
>>>> The former is WMS, the latter is not-WMS.
>>>> There is a very obvious speed difference between the two.
>>>> The reason the MapServer image has its colors wrong, for the record,
>> is
>>>> because it is using 8bit pngs instead of 24 bit pngs. My first
>>>> impression was that was the reason for the difference, but
>>>> unfortunately, 8bit gifs don't seem to fare any better.
>>>> Time for the URLs:
>>>> MapServer: real 0m0.660s
>>>> WMS: real 0m2.707s
>>>> These may help someone who knows MapServer investigate more.
>>>> Regards,
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
