[mapserver-users] Metadata Hashtable
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Sep 22 20:52:50 EDT 2008
Hi all,
I just looked through php_mapscript.c and I don't think there is a way
to do this in php because the function was never written to access the
hash table. You should probably write a bug on this for PHP/mapscript. I
don't think it is a problem for the swig stuff.
-Steve W.
Steve Lime wrote:
> I would thing this might work (perl in swig/mapscript):
> $hash = $layer->{metadata};
> $layer->{metadata} is a hashtableObj. In PHP there must be a get function to do this.
> Steve
>>>> On 9/22/2008 at 6:01 PM, in message <48D823D4.2030601 at planyukon.ca>, Jeff Hamm
> <jeff at planyukon.ca> wrote:
>> Thanks Steve.
>> Its finding the $hash I haven't got a handle on.
>> $oLayer->getMetaData("") wants a parameter key.
>> $oLayer->{metadata} returns nothing.
>> How do I grab the metadata hashtable itself?
>> Ticket #439 was the only reference I found; but the examples there are
>> same as above, unsuccessful.
>> Jeff
>> Steve Lime wrote:
>>> It should look something like this I believe (not a PHP guy):
>>> $key; # should be empty/NULL to start
>>> while($key = $hash->nextKey($key) {
>>> # do something with $key
>>> Steve
>>>>>> On 9/19/2008 at 3:38 PM, in message <48D40DB2.3080103 at planyukon.ca>, Jeff Hamm
>>>> Mapserver Bugzilla seems to indicate that exposing metadata as a proper
>>>> object is possible (Tickets #734 and #737).
>>>> I also want to print out all of the metadata key->value pairs for a map
>>>> layer using php-mapscript without explicitly naming them all.
>>>> Can anyone share a code snippet for this?
>>>> TIA
>>>> Jeff Hamm
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
