[mapserver-users] Mapserver and GDB files
Dave Fuhry
dfuhry at gmail.com
Tue Sep 23 16:25:16 EDT 2008
That, and the sudden syntax changes, all to SQL compliance:
delimit fields with "field", not [field]
wildcards _ and %, not ? and *
UPPER and LOWER, not UCASE and LCASE
and newly supported SQL clauses which ESRI is doubtful to have gone to
extra lengths to implement:
SELECT DISTINCT
GROUP BY, ORDER BY
Correlated sub-queries
Select list expressions
Trivial for a full-fledged db, but atypical for a single-file
persistence & query system.
-Dave
On Tue, Sep 23, 2008 at 3:42 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Not sure what you're seeing that screams "SQLLite", but I found this
> line on the final "Post 8.2" slide regarding access options
> interesting:
> "Home grown open source spatial data API (e.g. GDAL, FDO)"
> P.
> On Tue, Sep 23, 2008 at 12:21 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
>> Does anybody know if the .gdb format is SQLite-based? I remember
>> hearing rumors that ESRI's next geodatabase file format was to be.
>> I'm unable to find anything confirming or denying this online.
>> I read http://gis.esri.com/library/userconf/pug07/papers/workshops/file-gdb.pdf
>> as giving strong indications that it is.
>> -Dave
>> On Tue, Sep 23, 2008 at 1:23 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> Write an ArcGIS script to do all the work :) ArcGIS can export to
>>> Shape file and can read lyr files.
>>> Heck: http://arcscripts.esri.com/details.asp?dbid=12766
>>> P.
>>> On Mon, Sep 22, 2008 at 10:20 PM, Raivo Alla <snaperski at gmail.com> wrote:
>>>> Thank you all very much for answers.
>>>> I am working on a project, where all data is in .gdb files and styles in
>>>> ArcGIS .lyr format.
>>>> I guess both - getting .gdb and .lyr files working in mapserver environment
>>>> - are at the moment not possible?
>>>> So I must convert convert .gdb files (using FME maybe?) to some readable
>>>> format like shapefiles (if possible) and
>>>> just type manually mapserver symbology files... uhh.
>>>> Raivo
>>>> On Mon, Sep 22, 2008 at 7:19 PM, William Kyngesburye <woklist at kyngchaos.com>
>>>> wrote:
>>>>> On Sep 22, 2008, at 9:59 AM, Frank Warmerdam wrote:
>>>>>> Fawcett, David wrote:
>>>>>>> .gdb files are ESRI's new File Geodatabase proprietary format. I am
>>>>>>> quite sure that OGR/FWTools does not support it.
>>>>>> David,
>>>>>> Ah thanks. Indeed they are not supported and it is hard to imagine they
>>>>>> will be supported for a while. ESRI has indicated in the past that they
>>>>>> intend to provide an open mechanism to access the file geodatabase and
>>>>>> that
>>>>>> is still likely to happen at some point. However, I think this would be
>>>>>> quite a few months away at best.
>>>>> Hmmm, and if ESRI provides it, then, like SDE, it probably won't be
>>>>> available for OSX (or other linux platforms?). Bleh.
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "I ache, therefore I am. Or in my case - I am, therefore I ache."
>>>>> - Marvin
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
