[mapserver-users] Color filled transparent polygons
Reinoud Bokhorst
bokhorst at argoss.nl
Fri Sep 26 02:46:38 EDT 2008
Thank you for your answers.
At the time I installed mapserver 5.2, I didn't manage to compile in AGG support so I left it out. Of course that is then just the feature you need... I'll have to give it a retry.
Reinoud
Fawcett, David wrote:
> Of course Thomas would have had the right answer! I happily stand
> corrected.
> The opacity of overlapping symbols is cumulative.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas
> bonfort
> Sent: Thursday, September 25, 2008 4:48 AM
> To: Reinoud Bokhorst
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Color filled transparent polygons
> yes,
> from version 5.2 AND with AGG output, you can obtain this by setting the
> OPACITY keyword at the STYLE level.
> cheers,
> thomas
> On Thu, Sep 25, 2008 at 11:20, Reinoud Bokhorst <bokhorst at argoss.nl>
> wrote:
>> Hi,
>> I have a PostGIS table with about 12000 polygons scattered around the
>> globe. The polygons outline areas where I have particular model data.
>> To get an impression about the data density, I want to plot the
>> polygons with a fill color and a high transparency value. This would
>> mean that the colour on the map gets darker depending on how many
>> polygons overlap at a particular location because the color values
>> will add up. I can do this for example in QGIS but not in Mapserver.
>> It requires that the polygons themselves are drawn using a
>> transparency value but it seems that mapserver first draws all
>> polygons and them applies the transparency value to the resulting
>> image. Is there a solution for this?
>> Reinoud Bokhorst
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
