[mapserver-users] Variable substitution in FILTER request
with aLIKE
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Sep 29 13:02:15 EDT 2008
FILTER "WHERE NAME LIKE '%%road%%'" won't work? MapServer should just replace the inner %road% and
leave the outer %'s alone.
Steve
>>> On 9/28/2008 at 10:03 PM, in message <48E0FC44.379F.0037.0 at asurequality.com>,
"Robert Sanson" <SansonR at asurequality.com> wrote:
> I would like to have a FILTER section in my layer definition of an ArcSDE
> layer where I formulate a "WHERE NAME LIKE ...". The problem is, is that
> Mapserver defines variables using %variable%, and the "%" is also used as a
> wild card in SQL-Server, which is what we use for SDE.
> The Layer defition is:
> LAYER
> NAME road
> TYPE LINE
> UNITS METERS
> STATUS ON
> CONNECTIONTYPE SDE
> CONNECTIONTYPE PLUGIN
> CONNECTION "esri-arcsde,port:nnnn,sde_crs,user,passwd"
> PLUGIN "c:/ms4w/apache/specialplugins/msplugin_sde_91.dll"
> DATA "sde_crs.SDEADMIN.CRS_ROAD,SHAPE"
> FILTER "WHERE NAME LIKE '%" + %road% + "%'"
> # data is queryable
> DUMP TRUE
> Is there any solution to this?
> Many thanks,
> Robert Sanson
> The contents of this email are confidential to AsureQuality. If you have
> received this communication in error please notify the sender immediately and
> delete the message and any attachments. The opinions expressed in this email
> are not necessarily those of AsureQuality. This message has been scanned for
> known viruses before delivery. AsureQuality supports the Unsolicited
> Electronic Messages Act 2007. If you do not wish to receive similar
> communications in future, please notify the sender of this message.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com
