[mapserver-users] java mapscript + postgis = query use pixel
map's limits (SOLVED)
Ludovico Bianchini
metlud at yahoo.it
Mon Sep 29 16:29:17 EDT 2008
The error was the directive
TRANSFORM false
in LAYER "segnaletica".
(http://mapserver.gis.umn.edu/docs/reference/mapscript/index_html#layerobj)
I changed it with
TRANSFORM true
and now A-L-L work fine!!
Ludovico
Ludovico Bianchini ha scritto:
> This is the code
> LAYER
> NAME "segnaletica"
> STATUS on
> TYPE POINT
> TRANSFORM false
> POSTLABELCACHE true
> CONNECTION "user=user password=password dbname=dbname
> host=localhost port=5432"
> CONNECTIONTYPE postgis
> DATA "posizionegeoref from rilievi.impianti"
> CLASS
> STYLE
> COLOR 255 99 0
> SYMBOL "circle"
> SIZE 100
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> private void zoomIn(mapObj mapObj_o) {
> double[] extent = explodeExtent();//retrieve the previous map
> extent from the form data
> mapObj_o.setExtent(extent[0], extent[1], extent[2],
> extent[3]);//assign to the map the previous extent
> pointObj pointObj_o_pix = new
> pointObj(Integer.parseInt(getMap_x()),Integer.parseInt(getMap_y()),
> 0);//create a pixel-based point for the user //click
> rectObj rectObj_o = new rectObj(extent[0], extent[1],
> extent[2], extent[3],
> mapscript.MS_FALSE);//create a rectangle based on the
> previous extent
> mapObj_o.zoomPoint(2, pointObj_o_pix, WIDTH, HEIGHT, rectObj_o,
> null);//zoom in the map; WIDTH=600 pixel, HEIGHT=400 pixel
> draw(mapObj_o);
> private void draw(mapObj mapObj_o){
> imageObj mapImageObj;
> String imageName = getImageName();
> String imagePath = IMAGE_URL + imageName;
> mapImageObj = mapObj_o.draw();
> mapImageObj.save(imagePath, mapObj_o);
> setMappa("/map/" + imageName);
> setCurrent_extent(String.valueOf(mapObj_o.getExtent().getMinx()) + " " +
> String.valueOf(mapObj_o.getExtent().getMiny()) + " " +
> String.valueOf(mapObj_o.getExtent().getMaxx()) + " " +
> String.valueOf(mapObj_o.getExtent().getMaxy()));//set the actual
> extent in a hidden input element of the form
> I've tried also
> toggleLayer(mapObj_o);
> mapObj_o.setSize(WIDTH, HEIGHT);
> Umberto Nicoletti ha scritto:
>> On Sun, Sep 28, 2008 at 11:45 AM, Ludovico Bianchini
>> <metlud at yahoo.it> wrote:
>>> - Windows Vista Home Premium
>>> - Postgres 8.1
>>> - jvm 1.6.0
>>> - jboss 4.0.3SP1, tomcat 5.5
>>> - struts2
>>> - ms4w 2.3.0 (mapscript.jar, mapscript.dll, all other dlls taken
>>> from this
>>> pack)
>>> - postgresql-8.2-505.jdbc4.jar
>>> The query created to extract postgis layer is of the type
>>> SELECT asbinary(force_collection(force_2d(posizionegeoref)),'NDR') from
>>> rilievi.impianti where posizionegeoref && setSRID('BOX3D(0 0,599
>>> 399)'::BOX3D, find_srid('','rilievi.impianti','posizionegeoref') );
>>> The BOX3D filter is created using pixel map's limits...( BOX3D(0
>>> 0,599 399)
>>> ) why this?
>>> I use setExtent() before draw(), all navigation operations work
>>> fine, why is
>>> the query build against the pixel
>>> dimensions of the resulting image and not against the real dimensions
>>> calculated for the rectangle?
>> do you call setExtent before querying and convert image units into
>> map units?
>>> Perhaps I am missing some basic instructions, but I don't know what...
>>> Thanks in advance for any suggestions.
>>> Ludovico
>>> Chiacchiera con i tuoi amici in tempo reale!
>>> http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
