Fwd: [mapserver-users] WFS Filter with CGI Controls ?
Mehmet
m.sirin07 at googlemail.com
Wed Apr 1 14:29:17 EDT 2009
---------- Forwarded message ----------
Date: 2009/4/1
Subject: Re: [mapserver-users] WFS Filter with CGI Controls ?
To: Yewondwossen Assefa <yassefa at dmsolutions.ca>
hey,
that's an good idea! And it worked for example with EXPRESSION ('[type]' eq
'motorway')
thank you
kind regards
m.sirin
2009/3/31 Yewondwossen Assefa <yassefa at dmsolutions.ca>
Mehmet,
> One possibility would be to use variable substitution I guess: you can
> define your expression in the class with a value that would be replace from
> the url (http://mapserver.org/mapfile/variable_sub.html):
> something like this (not tested)
> EXPRESSION ("[TYPE]" = "%ms_type%"). You would then set
> my_type=residential in the url.
> Best Regards
> Mehmet wrote:
>> Hi,
>> For example I want to use the Openstreetmap data, more precisely streets.
>> And there are attributes like "name", "type", etc. Now I want to display
>> some features of "type" for instance by choosing "residential". The question
>> is: How to do that via URL and not by employing a client?
>> kind regards
>> 2009/3/30 Yewondwossen Assefa <yassefa at dmsolutions.ca <mailto:
>> yassefa at dmsolutions.ca>>
>> Hi There,
>> I am not sure I understand the question properly? Do you mean
>> getting the schema (attributes) of a layer? If that is the case
>> there is a DescribeSchema operation on a wfs server.
>> Best Regards
>> Mehmet wrote:
>> Hi, using the wfs_filter in a wms/wfs client works without
>> problems. But I wonder If can use "wfs_filter" via URL (not for
>> getting a XML File by GetFeature..that is I'm not meaning
>> &Filter=<Filter><
>> PropertyIsGreaterThan><PropertyName>AREA</PropertyName><Literal>100</Literal></PropertyIsGreaterThan></Filter>
>> It's for showing a dropdown menu in which users can choose what
>> type of roads they want to display (the geodata comes from
>> openstreetmap).
>> Is it possible?
>> By the way: I just have the Mapserver 4.10 running.
>> Thank you
>> M.Sirin
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Assefa Yewondwossen
>> Software Analyst
>> Email: assefa at dmsolutions.ca <mailto:assefa at dmsolutions.ca>
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090401/386de72c/attachment.html
