[mapserver-users] Error while getting flash output
Subha Ramakrishnan
subha at gslab.com
Thu Apr 2 01:54:10 EDT 2009
Sorry for that mistake. I figured out i was using the wrong mapserver
without flash support.
However, I am still not getting the flash output. I've set the imagetype
to "swf" and when I pass "Format=application/x-shockwave-flash" as
mention in the MIMEType in the OutputFormat, I get an error saying
"msWMSLoadGetMapParams: Image Handling Error.Unsupported output format
(application/x-shockwave-flash)."
Please let me know if anyone knows the reason or solution for this problem.
Thanks a lot for the help.
Subha
Yewondwossen Assefa wrote:
> The error message seems to indicate that you did not build MapServer
> with ming support. Can you do mapserv -v on the command like and
> check if you have OUTPUT=SWF?
> Subha Ramakrishnan wrote:
>> Hi All,
>> I am trying to get flash output from mapserver. I have compliled my
>> mapserver 5.2.2 with flash support.
>> But when i request for a layer, I am getting the following error:
>> "loadOutputFormat(): General error message. OUTPUTFORMAT clause
>> references driver SWF, but this driver isn't configured. "
>> This is my url:
>> "http://localhost/cgi-bin/mapserv?MAP=flashlayer.map&TRANSPARENT=true&LAYERS=flashlayer&FORMAT=image%2Fswf&PROJECTION=EPSG%3A4326&REPROJECT=false&
>> UNITS=m&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&
>> BBOX=4235678.0892222235,859902.5737739494,13628260.123222224,4404134.700666138&WIDTH=1920&HEIGHT=724"
>> Mapfile is as follows:(initial part with projection , extent etc
>> truncated)
>> OUTPUTFORMAT
>> NAME "swf"
>> MIMETYPE "application/x-shockwave-flash"
>> DRIVER "swf"
>> IMAGEMODE PC256
>> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
>> END
>> layer
>> name flashlayer
>> connectiontype postgis
>> connection "user= postgres dbname=flashtable host=localhost"
>> type polygon
>> group world
>> dump true
>> METADATA
>> "RESULT_FIELDS" "__ibp__id"
>> "SWFDUMPATTRIBUTES" "__ibp__id"
>> END
>> template "template.html"
>> projection
>> "init=epsg:4326"
>> end
>> transparency 65
>> status on
>> data "topology from flashtest using unique id using SRID = -1"
>> classitem "country"
>> class
>> name "INDIA"
>> expression "INDIA"
>> style
>> color 139 242 144
>> outlinecolor 000 000 000
>> end
>> end
>> end
>> Can some one please guide me as how to get the output in flash after
>> enabling the support?
>> Thanks a lot for any help.
>> Subha
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
