[mapserver-users] Layer scale problem with Mercator (EPSG:900913)
    paalkr
    pal.kristensen at statkart.no
    Thu Apr  2 07:42:04 PDT 2009
Hi!
Theres seems like there are some troubles with layers at different scales when requesting a map in EPSG:900913). I have set up the mapfile in EPSG:32633 (WGS84, UTM zone 33), and all the layers are as well sett to be in EPSG:32633. When requesting maps in in UTM zone 31 to 36 the layers switches at the right scales. The scale intervals could be is like this:
LAYER 1
   MINSCALE 2000000
LAYER 2
   MAXSCALE 2000000
   MINSCALE 800000
LAYER 3
   MAXSCALE 800000
   MINSCALE 100000
LAYER 4
   MAXSCALE 100000
When requesting a map covering approx the same area (see attached images), different layers are turned on in mapserver (shows as different level of detail in the maps).
Is there a workaround for this? I guess that the issue has something to do with how scales are calculated in mapserver.
PS! The same issue is present when requesting maps in geographic coordinate systems like EPSG:4326. The maps are generated with WMS GetMap requests.
UTM33
Mercator
Regards,
Pål Kristensen
View this message in context: http://n2.nabble.com/Layer-scale-problem-with-Mercator-%28EPSG%3A900913%29-tp2575585p2575585.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
