[mapserver-users] AGG Rendering
Andrew Ayre
andy at britishideas.com
Fri Apr 3 02:08:18 EDT 2009
Hi! I can't seem to get AGG to work. Currently my output is not
antialiased. Can anyone give me some hints? Thanks!
Note that I have built AGG 2.5 with freetype support. Also note that I
needed two
./configure --with-postgis=/usr/bin/pg_config --with-wfs --with-proj
--with-geos=/usr/bin/geos-config --with-gd=/usr/local/ --with-jpeg
--with-ogr=/usr/bin/gdal-config --with-gdal=/usr/bin/gdal-config
--with-agg=/usr/local/src/agg-2.5 --with-freetype
MapServer is now configured for
-------------- Compiler Info -------------
C compiler: gcc -O2 -fPIC -Wall
C++ compiler: g++ -O2 -fPIC -Wall
Debug:
Generic NINT:
-------------- Renderer Settings ---------
zlib support: -DUSE_ZLIB
png support:
palette rgba png support:
jpeg support:
iconv support: -DUSE_ICONV
AGG support: -DUSE_AGG
AGG Freetype support: agg_font_freetype.o
Ming(flash) support:
PDFLib support:
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Libxml2 support:
FriBidi support:
Curl support:
FastCGI support:
Threading support:
GEOS support: -DUSE_GEOS
-------------- Data Format Drivers -------
native tiff support:
PostGIS support: -DUSE_POSTGIS
EPPL7 support: -DUSE_EPPL
ArcSDE support:
OGR support: -DUSE_OGR
GDAL support: -DUSE_GDAL
Oracle Spatial support:
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client:
WFS Server: -DUSE_WFS_SVR
WFS Client:
WCS Server:
SOS Server:
-------------- MapScript -----------------
PHP MapScript: no
./mapserv.cgi -v
MapServer version 5.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=GEOS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
OUTPUTFORMAT
NAME 'AGG_Q'
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
This is the error message I get:
loadOutputFormat(): General error message. OUTPUTFORMAT clause
references driver AGG/PNG, but this driver isn't configured.
Andy
Andy
PGP Key ID: 0xDC1B5864
