[mapserver-users] How to access Templating: Map Geometry
Variables(or Equivalent) from OGR Connection
joncoign
jncoign at Knology.net
Fri Apr 3 14:38:06 EDT 2009
I haven't built MapServer before I have been using MS4W builds. However, if you can show me where to make this change I will be happy to get up to speed and work on the change.
Jon
This would be a feature request. The runtime subs are done well ahead of the computation
of things like map extent. This would be a relatively simple hack and I can show you where
in the CGI code to try it out if you'd like.
Steve
View this message in context: http://n2.nabble.com/Re%3A-How-to-access-Templating%3A-Map-Geometry-Variables%28or-Equivalent%29-from-OGR-Connection-tp2581092p2582268.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
