[mapserver-users] hiow can i convert mapinfo workspace to
mapserver mapfile?
Andrew Williams
AWilliams at rapidmap.com
Mon Apr 6 01:58:08 EDT 2009
The MBX is a Mapinfo\Mapbasic Executable.
If you don't have Mapinfo nothing is going to work.
Not knowing the exact methodology behind the code it's hard to know what to do next. You could try just double clicking the MBX and see what happens. I would expect Mapinfo to start and then a dialog asking which Workspace you'd like to convert is located.
Alternatively start Mapinfo and go to the Tools menu and select Run Mapbasic Program and then select the wor2map.mbx. This will either create a new menu item or pop up a dialog, again asking where the workspace is you wish to convert.
Hope this helps.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of meenu
Sent: Monday, 6 April 2009 3:59 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] hiow can i convert mapinfo workspace to mapserver mapfile?
hi all...advance thanks...i downloaded wor2map.zip for converting mapinfo workspace to mapserver map file...but how can i use this wor2map for this convertion...in this folder 3 files is there .MBX,.MB,.DEF...how can use this files for converting my mapinfo files to mapserver mapfle???
Meenu
View this message in context: http://n2.nabble.com/hiow-can-i-convert-mapinfo-workspace-to-mapserver-mapfile--tp2591481p2591481.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
