[mapserver-users] displaying LINESTRING elements from shapefiles
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Apr 6 10:03:03 EDT 2009
This layer shows OSM roads for me from the same shapefiles that you are
trying to use.
LAYER
NAME "OSM_roads"
STATUS ON
DATA "d:\Data\OSM\roads"
TYPE LINE
UNITS METERS
METADATA
"wms_title" "OSM_tiet"
END
CLASS
NAME "roads"
OUTLINECOLOR 0 255 0
END
PROJECTION
"init=epsg:4326"
END
END
Check that EXTENT in your mapfile suits the data.
-Jukka Rahkonen-
Adrian Popa wrote:
> Hello everybody,
> I'm trying to display a map generated from openstreetmaps and
> saved as several shapefile layers. The map was obtained from:
> http://download.geofabrik.de/osm/europe/
> The shapefile "roads.shp" has a data type of "LINESTRING":
> [root at alarms romania-osm-shp]# ogrinfo -al roads.shp | head -30
> INFO: Open of `roads.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: roads
> Geometry: Line String
> Feature Count: 51469
> Extent: (20.379788, 43.653826) - (29.712869, 48.221387) Layer SRS WKT:
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_1984",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]]
> osm_id: Real (16.0)
> type: String (16.0)
> oneway: Integer (1.0)
> OGRFeature(roads):0
> osm_id (Real) = 1349
> name (String) = Bulevardul Mircea Eliade
> type (String) = tertiary
> oneway (Integer) = 0
> LINESTRING (26.093111799999999 44.469673499999999,26.093683899999998
> 44.469124899999997,26.094064299999999 44.468571799999999,26.0961094
> 44.465648600000002)
> I've tried creating the MAP file with a layer type of
> LINE/LINESTRING/POLYGON, but the map would not display the
> layer (however mapserver would generate an image).
> My version of mapserver is 4.10.3 (fedora core 8).
> My question is: can I display this data type directly with
> mapserver, or do I need to convert it to something else? Is
> my version of mapserver too old to display this data?
> Thanks.
> Adrian
> mapserver-users at lists.osgeo.org
