[mapserver-users] label display stops abruptly
Thomas Bonfort
thomas.bonfort at camptocamp.com
Mon Apr 6 13:42:52 EDT 2009
LABEL_NO_CLIP is so that labels aren't repeated on each tile.
what you want here is PARTIALS FALSE in each of your label blocks
thomas
On Mon, Apr 6, 2009 at 7:29 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Looking at the screen capture (at Nabble
> http://n2.nabble.com/label-display-stops-abruptly-td2585479.html#a2585479),
> it could be the classic tile-clipping-labels problem. Is the solution to
> add
> PROCESSING "LABEL_NO_CLIP=True"
> before the LABEL definition?
> Brent Fraser
> Steve Lime wrote:
>> Hi Pradeep: You didn't attach the graphic, plus we need to know more about
>> the data and MapServer
>> version to do much.
>> Steve
>>>>> On 4/4/2009 at 10:53 AM, in message
>>>>> <1238860430468-2585479.post at n2.nabble.com>,
>> new2ms4w <nagal005 at umn.edu> wrote:
>>> Hi,
>>> I display some roads on a map along with the names of the roads as
>>> labels. The label display has a minor problem. Sometimes the name of the
>>> label is only displayed partially. I don't know why.
>>> Here is a screen-shot of the problem. I've circled in red where the
>>> labels are not displaying properly.
>>> And the mapfile code which deals with label display is here:
>>> LABELCACHE on
>>> LABEL
>>> TYPE truetype
>>> FONT "arial"
>>> SIZE 8
>>> OUTLINECOLOR 255 255 255
>>> COLOR 0 0 0
>>> POSITION lc
>>> MINDISTANCE 100
>>> MINFEATURESIZE auto
>>> ANGLE auto
>>> #WRAP \' \'
>>> END #end label
>>> Can someone tell me what am I missing here.
>>> Thanks,
>>> Pradeep
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
www.camptocamp.com
+33 4 79 26 57 97
