[mapserver-users] label display stops abruptly
    new2ms4w
    nagal005 at umn.edu
    Mon Apr  6 21:39:52 PDT 2009
Hello,
I've tried out both the options suggested above and none of them work.
If I use  OpenLayers.Layer.MapServer.Untiled, then this problem doesn't occur. But ofcourse, I want to have the cool tiling effect.
I'm using Mapserver 5.2.1 with OpenLayers. My data consists of only linear features.
And the screen capture is here http://n2.nabble.com/file/n2585479/badlabel.jpg
Thanks
LABEL_NO_CLIP is so that labels aren't repeated on each tile.
what you want here is PARTIALS FALSE in each of your label blocks
thomas
View this message in context: http://n2.nabble.com/label-display-stops-abruptly-tp2585479p2597034.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
