[mapserver-users] getExtent(c#) with Postgis data ...
Tamas Szekeres
szekerest at gmail.com
Tue Apr 7 16:12:13 EDT 2009
I tought you were looking for the layer extent not just the extent of a
shape.
Tamas
2009/4/7 Paul james <pauljame at gmail.com>
> Thanks!
> But I resolved my problem using shapeObj, without OGR...
> My code:
> _layer.open();
> shapeObj _shape = new shapeObj((int)_layer.type);
> _layer.getShape(_shape, -1, Convert.ToInt32(__id));
> _map.extent.maxx = _shape.bounds.maxx +0.1;
> _map.extent.maxy = _shape.bounds.maxy + 0.1;
> _map.extent.minx = _shape.bounds.minx - 0.1;
> _map.extent.miny = _shape.bounds.miny - 0.1;
> On Tue, Apr 7, 2009 at 3:29 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Paul,
>> You can refer to the ogrinfo C# sample application in the gdal source
>> tree:
>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/ogrinfo.cs
>> Best regards,
>> Tamas
>> Thanks Tamas...
>>> But now I´m a little lost... Am I supposed to create a OGR layer?
>>> Do you have any sample how to get extent´s layer using OGR?
>>> P
>>> On Mon, Apr 6, 2009 at 6:30 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>> Choose a package with the best match for your compiler and architecture
>>>> from here:
>>>> http://vbkto.dyndns.org:1280/sdk/index.html
>>>> Best regards,
>>>> Tamas
>>>> 2009/4/6 Paul james <pauljame at gmail.com>
>>>>> Where can I find ogr_csharp.dll ?
>>>>> Thanks Tamas!
>>>>> Paul
>>>>> On Mon, Apr 6, 2009 at 6:22 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>>> Paul,
>>>>>> Unfortunately this function is not implemented by the MapServer
>>>>>> postgis driver, you might want to use the OGR C# API (ie. ogr_csharp.dll)
>>>>>> for this purpose.
>>>>>> Best regards,
>>>>>> Tamas
>>>>>>> All value from getExtent (Postgis layer) is : 3.4028234663852886E+38
>>>>>>> Is it a bug?
>>>>>>> On Mon, Apr 6, 2009 at 5:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>>>>> Why don't? That function have already been exposed for *layerObj*with the following signature:
>>>>>>>> *public rectObj getExtent(void)*
>>>>>>>> Best regards,
>>>>>>>> Tamas
>>>>>>>>> Hello, It seems that getExtent (c#) is not implemented...
>>>>>>>>> Any other solution to get extent of a layer using mapscript?
>>>>>>>>> Paul
>>>>>>>>> _______________________________________________
>>>>>>>>> mapserver-users mailing list
>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090407/9280cc06/attachment-0001.html
