[mapserver-users] Re: Problem with projection
    John Westwood
    John.Westwood at port.ac.uk
    Wed Apr  8 06:02:00 PDT 2009
Hi
There is an spurious " symbol in your PROJECTION definition, I'm not
sure if that is significant (probably not). Looking at your picture
though, it looks like a datum or ellipsoid mismatch. Is your data in
WGS84 or some other datum or ellipsoid? Check out the Wikipedia page:
http://en.wikipedia.org/wiki/Geographic_coordinate_system
You may also wish to check that OpenLayers is using the same coordinate
system as MapServer.
Regards
John Westwood
>>> Valeria Muñoz <valemunoz at gmail.com> 07/04/09 6:04 PM >>>
I am sorry I forget something, my projection is:
PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
2009/4/7 Valeria Muñoz <valemunoz at gmail.com>
> HI
>  I think I have problems with my PROJECTION but i do not why.. i have
a
> list of adress with latitude and longitude of them but the point is
not in
> the correct position. please look the image i mark with X where should
be
> Attach image
More information about the MapServer-users
