[mapserver-users] TR: Blank map
    Rahkonen Jukka
    Jukka.Rahkonen at mmmtike.fi
    Tue Apr 14 02:35:18 PDT 2009
Any possibility that it could have something to do with WMS version 1.3 that flipped the coordinate axis order?  Did you also previously use WMS 1.3?
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Clément MONIER
> Lähetetty: 14. huhtikuuta 2009 11:26
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] TR: Blank map
> This issue (see below) is still active with MS 5.4 rc1.
> Can anyone help me ?
> Thanks
> Clement
> -----Message d'origine-----
> De : mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] De la part
> de Clément MONIER Envoyé : mardi 7 avril 2009 10:55 À :
> mapserver-users at lists.osgeo.org Objet : [mapserver-users] Blank map
> Hi,
> MapServer returns blank images since I upgraded to MS4W 2.3.1
> + mapserver_ms4w-5.4.0-beta4.
> Though I've followed the upgrade tips and changed my mapfiles :
> http://lists.osgeo.org/pipermail/mapserver-users/2009-March/06
> 0600.html
> You'll find as attachment a very simple test case (.map + shapefiles).
> Here's the request that should (and used to) return a map :
> http://localhost/cgi-bin/mapserv.exe?MAP=C:\ms4w\apps\gmap\htd
> ocs\test.map&SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=l
> ayer1&STYLES=&FORMAT=agga&BGCOLOR=0xFFFFFF&TRANSPARENT=True&SR
> S=EPSG:4326&BBOX=2.48,48.82,2.50,48.84&WIDTH=512&HEIGHT=512
> I suspect a projection issue because the following request
> (with a world-wide bbox) does display some features (look for
> a small green point on the left side) :
> S=EPSG:4326&BBOX=-90,0,90,180&WIDTH=512&HEIGHT=512
> Has anything changed inside the Proj4 library ?
> Thanks for your help
> Clément
More information about the MapServer-users
