[mapserver-users] missing dll problem!!!
    Rahkonen Jukka
    Jukka.Rahkonen at mmmtike.fi
    Tue Apr 14 04:24:41 PDT 2009
Open the command window and run setenv.bat from \ms4w\ directory first.  I suppose you are using ms4w.  If not, the cure is the same, that is, set the paths correctly.
-Jukka Rahkonen-
	Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Mukul Gupta
	Lähetetty: 14. huhtikuuta 2009 14:12
	Vastaanottaja: mapserver-users at lists.osgeo.org
	Aihe: [mapserver-users] missing dll problem!!!
	Hi
	I tried running ogr2ogr.exe but a error message comes that application failed to start because gdal16.dll is missing.Although when I cross checked it, the dll is present in Apache\cgi-bin folder.
	Tell me what to do with it.
	--Mukul
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090414/32f33a03/attachment.htm>
More information about the MapServer-users
