[mapserver-users] Mapserver 5.0.3 on Ubuntu 8.10-AMD64	TrueType font problem
    Martin Koch
    m.koch at bridgis.nl
    Tue Apr 14 23:35:20 PDT 2009
Thanks for your interest,
When I change something in the path to the fontset, I invoke this error
msLoadFontset(): Unable to access file. Error opening
fontset /mapserver/mapdata/font/fonts.txt. (which is the crippled path)
When I change something in the path to the desired font in the fontset I
invoke this error...
msGetLabelSize(): TrueType Font error. Could not find/open font
This made me conclude my paths are correct and/or the font is opened
with the correct paths..
Directing the errors to apache's error.log yields these two lines:
[Wed Apr 15 08:40:15 2009] [error] [client 192.168.34.85] CGI Request 1
on process 31346
[Wed Apr 15 08:40:16 2009] [error] [client 192.168.34.85] Premature end
of script headers: mapserv
from which I conclude the process has started and prematurely ended...
Kind regards,
Martin
_____________________________
Martin Koch
Teamleider data
Bridgis b.v.
Sint Walburgkerkpad 3
4001 MG Tiel
Op vrijdag 10-04-2009 om 09:55 uur [tijdzone -0400], schreef Daniel
Morissette:
> Martin Koch wrote:
> > I used the same mapfiles. Everything works fine appart but when
> > I use TrueType fonts for displaying labels I get a '500 Internal Server
> > Error'. A default bitmap-font works well, but not the truetype font's I
> > refer to in my fontset.
> > I checked all my path's tripple, compared both servers for different
> > right's settings, apache2 settings and installed packages. I reinstalled
> > dependencies as libfreetype6 but still 'no go' with truetype.
> I'd say check the paths inside your fontset again. I found and fixed a
> very similar issue in v5.2 earlier this week, and it was caused by the
> font file not being found. I would not be surprised if the same issue
> existed in 5.0 as well:
>    http://trac.osgeo.org/mapserver/ticket/2973
> Another hint: set CONFIG MS_ERRORFILE "stderr" in your mapfile and look
> for any error in the Apache error_log. In the case of the ticket above,
> the "font not found" error was not trapped properly but it would have
> showed up in the error_log before the crash (unless stderr buffering
> would have prevented it from getting to the log file before the crash).
> Daniel
More information about the MapServer-users
