[mapserver-users] Painting outside a polygon.
Fawcett, David
David.Fawcett at state.mn.us
Mon Apr 20 11:17:48 EDT 2009
I am not sure if this meets your case or not.
If you simply want to set the background color of the map to blue, you
can set IMAGECOLOR 0 0 255 at the map level. (of course, you may want to
pick a nicer shade of blue...)
http://mapserver.org/mapfile/map.html
This will put a blue background behind in the areas not covered by your
polygons.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ernesto
Barrera
Sent: Monday, April 20, 2009 8:42 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Painting outside a polygon.
Hi there,
I'm dealing with a layer containing polygon data for a given country
(shapefile).
Color inside the polygon can be easily set via COLOR style parameter.
I'm just looking for a way to apply color to the outside of the polygon
(i.e.:, paint the surrounding sea in solid blue)
Is there such a method inside Mapserver?
Is there a way to 'reverse' the shapefile to indicate that the wanted
feature is not inside the boudaries but the complementary area?
Thanks in advance,
PD.: My single layer is like this
LAYER
NAME mycountry
DATA mycountry.shp
TYPE POLYGON
STATUS ON
CLASS
NAME "boundaries"
STYLE
COLOR 255 0 0 # country area shown in red
END
END
END
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
