[mapserver-users] python mapscript AGG problem
Guillaume Sueur
no-reply at neogeo-online.net
Tue Apr 21 06:38:02 EDT 2009
I guess that the mapscript you are using with python is not the proper
one. Did you go to mapserver/mapscript/python and run setup.py install ?
Note that integration of agg in python-mapscript is not trivial due to
some limitations in the agg lib.
regards
Guillaume
dzizes a écrit :
> HEllo!
> I've compiled mapserver against AGG on linux. My web application that works
> with mapserver renders nice images with the use of AGG library.
> /usr/lib/cgi-bin$ ./mapserv -v
> MapServer version 5.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI
> SUPPORTS=THREADS INPUT=TIFF INPUT=EPPL7 INPUT=ORACLESPATIAL INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> However, when I try to open simple mapfile with mapscript - python craches.
> Python 2.5.2 (r252:60911, Jul 31 2008, 17:28:52)
> [GCC 4.2.3 (Ubuntu 4.2.3-2ubuntu7)] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
>>>> import mapscript
>>>> m = mapscript.mapObj('/tmp/test.map')
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "/usr/lib/python2.5/site-packages/mapscript.py", line 1267, in
> __init__
> this = _mapscript.new_mapObj(*args)
> _mapscript.MapServerError: loadOutputFormat(): General error message.
> OUTPUTFORMAT clause references driver AGG/PNG, but this driver isn't
> configured.
> # mapfile output specification
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> FORMATOPTION "TRANSPARENT=ON"
> FORMATOPTION "INTERLACE=OFF"
> FORMATOPTION "QUANTIZE_FORCE=OFF"
> END
> Any ideas what might be wrong?
