[mapserver-users] python mapscript AGG problem
dzizes
dzizes451 at gmail.com
Tue Apr 21 07:42:22 EDT 2009
I know that its not proper. It is standard one which goes with default linux
package.
I'm wandering if there is a way for upgrading python mapscript module with
reference to AGG library.
Michał
On Tue, Apr 21, 2009 at 12:38 PM, Guillaume Sueur <
no-reply at neogeo-online.net> wrote:
> Hi,
> I guess that the mapscript you are using with python is not the proper
> one. Did you go to mapserver/mapscript/python and run setup.py install ?
> Note that integration of agg in python-mapscript is not trivial due to
> some limitations in the agg lib.
> regards
> Guillaume
> dzizes a écrit :
> > HEllo!
> > I've compiled mapserver against AGG on linux. My web application that
> works
> > with mapserver renders nice images with the use of AGG library.
> > /usr/lib/cgi-bin$ ./mapserv -v
> > MapServer version 5.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
> SUPPORTS=FASTCGI
> > SUPPORTS=THREADS INPUT=TIFF INPUT=EPPL7 INPUT=ORACLESPATIAL INPUT=OGR
> > INPUT=GDAL INPUT=SHAPEFILE
> > However, when I try to open simple mapfile with mapscript - python
> craches.
> > Python 2.5.2 (r252:60911, Jul 31 2008, 17:28:52)
> > [GCC 4.2.3 (Ubuntu 4.2.3-2ubuntu7)] on linux2
> > Type "help", "copyright", "credits" or "license" for more information.
> >>>> import mapscript
> >>>> m = mapscript.mapObj('/tmp/test.map')
> > Traceback (most recent call last):
> > File "<stdin>", line 1, in <module>
> > File "/usr/lib/python2.5/site-packages/mapscript.py", line 1267, in
> > __init__
> > this = _mapscript.new_mapObj(*args)
> > _mapscript.MapServerError: loadOutputFormat(): General error message.
> > OUTPUTFORMAT clause references driver AGG/PNG, but this driver isn't
> > configured.
> > # mapfile output specification
> > OUTPUTFORMAT
> > NAME png
> > DRIVER "AGG/PNG"
> > MIMETYPE "image/png"
> > IMAGEMODE RGB
> > EXTENSION "png"
> > FORMATOPTION "TRANSPARENT=ON"
> > FORMATOPTION "INTERLACE=OFF"
> > FORMATOPTION "QUANTIZE_FORCE=OFF"
> > END
> > Any ideas what might be wrong?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090421/ebbf8898/attachment-0001.html
