[mapserver-users] MapServer 4 vs 5 seg fault
Michael E Masscotte
masscotm at erau.edu
Tue Apr 21 11:36:11 EDT 2009
I haven't tried RHEL5 yet, but it happens with RHEL 4 and Solaris 10.
Liz Godwin wrote:
> I've noticed a similar problem with EXPRESSION statements, but
> inconsistantly. Are you running MS on Red Hat 5 by any chance?
> On Tue, Apr 21, 2009 at 11:05 AM, Michael E Masscotte
> <masscotm at erau.edu <mailto:masscotm at erau.edu>> wrote:
> I've done some more investigation and found the seg fault happens
> with a call to msDrawRasterLayerGDAL() according to gdb. I also
> found what is tripping the core dump in the map file. I have an
> class with 'EXPRESSION ([pixel] > 0)' so mapserver does not draw
> black pixels. When I remove this, it works fine although it has
> the black pixels I don't want. So, it appears I'm doing something
> wrong with the EXPRESSION statement. Any one have any ideas how to
> fix this or workaround it? Again, what I find strange is that this
> works fine in MapServer 4.x but not 5.x.
> Thanks for your help,
> -Mike
> Michael E Masscotte wrote:
> I have a php script that generates a png from geotiff tiles.
> The tiles are indexed using gdaltindex. The php script works
> fine for MapServer 4.10.x but seg faults for version 5.x.x.
> Does anyone know of any differences between version 4 and 5
> that would cause this? Could it be from an older version of
> gdal that the tiles are being generated with? This happens in
> both RedHat Linux 4 as well as on our Solaris machines. I can
> provide more details if someone can point me in the right
> direction on where to look first for a problem.
> Thanks is advance for any insight any one might provide!
> -Mike
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
