[mapserver-users] problem with my "label"
Hendra Satya
hendra.satya at gmail.com
Tue Apr 21 12:31:05 EDT 2009
Maybe you forget to add this statement:
TYPE POLYGON
LABELITEM "NM_DESA" #field label to display
METADATA
"DESCRIPTION" "Tanah"
END
Hope helps
Regards,
Henda Satya
AVOID Jakarta traffic - join http://www.bebasmacet.com and follow
http://twitter.com/bebasmacet
On Tue, Apr 21, 2009 at 11:22 PM, MeLv1n wAuRaN (via Nabble) <
ml-user+174339-1550548835 at n2.nabble.com<ml-user%2B174339-1550548835 at n2.nabble.com>
> wrote:
> Hi all,
> i have a problem that needs to be solved soon. I included a label in a
> layer but the label does not appear in my browser. In the .dbf file, the
> informations i want to display as the labels are in the 5th column with the
> name "NM_DESA"
> i use openlayers 2.7 to run my mapserver mapfile. Can anyone help me? thx
> here's my detail:
> LAYER
> NAME "Tanah"
> DATA "Desa"
> STATUS ON
> TYPE POLYGON
> METADATA
> END
> CLASS
> LABEL
> FONT "sans"
> TYPE TRUETYPE
> SIZE 8
> BUFFER 1
> COLOR 0 0 0
> FORCE TRUE
> END
> COLOR 225 200 100
> OUTLINECOLOR 0 0 0
> END
> END
> Cheers,
> Melvin
> mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2671032&i=0>
> View message @
> http://n2.nabble.com/problem-with-my-%22label%22-tp2671032p2671032.html
> To start a new topic under Mapserver - User, email
> ml-node+1969211-1631322126 at n2.nabble.com<ml-node%2B1969211-1631322126 at n2.nabble.com>
> To unsubscribe from Mapserver - User, click here< (link removed) >.
View this message in context: http://n2.nabble.com/problem-with-my-%22label%22-tp2671032p2671094.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090421/8f2283d8/attachment.html
