[mapserver-users] Grid Layer : different intervals from X and
Y axis
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Apr 24 13:34:53 EDT 2009
Hi Eduardo,
Not currently from what I can see. The interval values given in the
map file applies for both axis. Could you open an enhancement bug on
it, and I will look into adding that.
bes Regards,
Eduardo Kanegae wrote:
> Hi,
> I´m currently using grid object for composing grid layers but I´d like
> to draw X and Y axis using different interval values.
> Example: 1 deg for Y and 1.5 deg for X.
> Is there any trick to do that using grid layer?
> best
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
