[mapserver-users] Symbol sizes
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Apr 27 08:45:55 EDT 2009
I can't see connectiontype, connection or data in the layer definitions. Have you just removed them from your mail, or are they really missing from the mapfile? Even if you wouldn't like to reveal the real parameters it would help to see the idea of how you read the database.
-Jukka Rahkonen-
Peter Rose wrote:
Hi G,
Classitem and expressions are fine when you are using a shapefile but as I
said my data is stored in a MySQL database where these don't seem to work.
Here is a copy of the mapfile I tried to use but it still doesn't work!
# POI layer - points of interest
LAYER
NAME "poi"
STATUS default
TYPE point
LABELCACHE on
CLASS
NAME "Large fiscal"
EXPRESSION ([fiscal] < 1)
STYLE
SYMBOL "Circle"
SIZE 8
COLOR 255 0 0
BACKGROUNDCOLOR 255 0 0
END
END # class
CLASS
NAME "Small fiscal"
EXPRESSION ([fiscal] > 1)
STYLE
SYMBOL "Circle"
SIZE 8
COLOR 0 255 0
BACKGROUNDCOLOR 0 255 0
END
END # class
END # layer poi
No classitem need be specified if you use expressions and in fact they will
be ignored if present but as I said this only works with shapefiles not with
MySQL.
Thanks for your suggestion.
Peter
View this message in context: http://n2.nabble.com/Symbol-sizes-tp2717421p2724379.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
