[mapserver-users] C# connectiontype issue
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Tue Apr 28 00:21:36 EDT 2009
I am using below map file code for loading raster data. below is my code.
I think the problem with jpeg.convert into tiff or geo tiff etc.. it may
work.
###### Heat Maps #######
Layer # Layer starts here
Name "Hyderabad"
GROUP "Heat Maps"
Data "..\Raster\hyderabad.tif"
PROCESSING "SCALE=1,15399.12305" // these are optional you need not use
PROCESSING "SCALE_BUCKETS=10" // these are optional you need not use
CLASSITEM "[pixel]"
TYPE RASTER
Status On
CLASS
Name "Class One"
EXPRESSION ([pixel] > 1 AND [pixel] < 5133.041016)
STYLE
COLOR 255 255 0
END
END
CLASS
Name "Class Two"
EXPRESSION ([pixel] > 5133.041017 AND [pixel] < 10266.08203)
STYLE
COLOR 0 166 255
END
END
CLASS
Name "Class Three"
EXPRESSION ([pixel] > 10266.08204 AND [pixel] < 15399.12305 )
STYLE
COLOR 255 0 0
END
END
End # end of the State Layer
Thanks,
Venkat
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Murty Maganti
Sent: Tuesday, April 28, 2009 1:11 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] C# connectiontype issue
Hi
I have a raster layer in map file. When I load the map file using C# map
script, at run time it shows layerObj.connectiontype as
'MS_CONNECTION_TYPE.MS_SHAPEFILE' though it is raster image. Is there any
syntax error with my map file definition. I need to know exactly whether it
is a raster or vector layer in my application. Some logic in my application
needs to handle them differently.
This is the entry in map file
LAYER
DATA "14m_jpg_24bit.jpg"
NAME " 14m Jpg 24bit"
STATUS ON
TYPE RASTER
UNITS METERS
END
Thanks
Murty
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090428/57ed2d11/attachment-0001.html
