[mapserver-users] Re: Mapserver native connection with oracle
spatial
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Tue Apr 28 00:35:54 EDT 2009
Hi list,
there are some problems with the hard drives (RAID) and maybe that is the
cause.
When the problem is solved and have some news, i will let you know.
Thanks,
2009/4/27 Luigi Castro Cardeles <luigi.cardeles at gmail.com>
> Hi list,
> I was trying to connect to a layer on oracle spatial using mapserver native
> connection but i find some problems:
> When i try to load the layer (using mapserver cgi or command line), this
> message appears:
> /var/www/cgi-bin/mapserv "QUERY_STRING=map=app.map&mode=map"
> *** glibc detected *** /var/www/cgi-bin/mapserv: free(): invalid next size
> (fast): 0x09c23740 ***
> ======= Backtrace: =========
> /lib/libc.so.6[0x6c8d06]
> /lib/libc.so.6(cfree+0x90)[0x6cc1e0]
> /var/www/cgi-bin/mapserv[0x80f2b6e]
> /var/www/cgi-bin/mapserv[0x80706be]
> /var/www/cgi-bin/mapserv[0x80765e7]
> /var/www/cgi-bin/mapserv[0x80529ca]
> /var/www/cgi-bin/mapserv[0x8054ac0]
> /lib/libc.so.6(__libc_start_main+0xdc)[0x675dec]
> /var/www/cgi-bin/mapserv[0x80516f1]
> Configuration:
> CentOS 5 - 2.6.18-92.1.22.el5.centos.plus x86.
> Oracle 10.2.0.1 + Oracle Spatial.
> Mapserver 5.4.0
> ./mapserv -v
> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS
> SUPPORTS=GEOS INPUT=TIFF INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR
> INPUT=GDAL INPUT=MYGIS INPUT=SHAPEFILE
> I already set the permission of the files and enviroment variables (at
> /etc/profile and apache conf's).
> using sqlplus at that machine i can connect.
> That mapfile has other layers from other fonts (postgis, shp), they load
> without problem,
> I can load the oracle spatial layer using a java client without problem.
> Any hint?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090428/e773cff6/attachment.html
