[mapserver-users] How to link Oracle attributes to SHAPEFILE
    pbg
    pbg at tragsa.es
    Tue Apr 28 02:45:57 PDT 2009
Hi Roald.
Thanks for the reply.
In this project, we are required to use SHAPEFILES and Oracle, so we can't
change this environment.
Roald de Wit wrote:
> Hi Pedro,
> A number of years ago i had a situation like you describe below. The
> solution we chose was:
> - Create a postgresql/postgis datawarehouse
> - Import shapefiles into postgis (shp2psql or ogr2ogr)
> - Import attribute info from oracle into postgresql (we needed a
> commercial license for converting Oracle to Postgresql)
> - Either create a view or merge tables to join the geometry and
> attribute info
> - Serve the lot through MapServer WFS/WMS
> I hope this helps.
> Regards, Roald
> Pedro Briones García wrote:
>> Hello.
>> I’m working with *Oracle 10g* and *MapServer 5.2*. My geographic layers
>> are SHAPEFILES and the attributes of SHAPEFILES are stored in Oracle 10g
>> (*NOT* Oracle Spatial or Locator)
>> I need to link (or join) SHAPEFILES with attribute (NOT spatial) tables
>> to do 3 things:
>> -        Draw only elements of SHAPEFILE that are related with some
>> records in Oracle. A record (polygon, for example) in the SHAPEFILE
>> should only draw if is related with a record in Oracle (they both have a
>> common column).
>> -        Make a thematic map wich classifications depending on the values
>> of Oracle records.
>> -        Draw only elements of SHAPEFILE that meet an Oracle condition
>> I have found lots of examples of layers wich both, geometry and
>> attribtes, in Oracle; or layers in Oracle Spatial, but none of how to
>> link and use a SHAPEFILE with Oracle (not spatial).
>> I too would like to do the same of the aforementioned, but in this
>> case with *DBF files* instead of Oracle tables. I have seen an example
>> in the documentation, but I don’t know distinguish SHAPEFILES and the
>> DBF files in the sentence.
>> Please, could somebody send me an example to easily understand this?
>> Thanks in advance.
>> TRAGSATEC
> Roald de Wit
> Software Engineer
> roald.dewit at lisasoft.com
> Commercial Support for Open Source GIS Software
> http://lisasoft.com/LISAsoft/SupportedProducts/
> The contents of this email are confidential and may be subject to legal or
> professional privilege and copyright. No representation is made that this
> email is free of viruses or other defects. If you have received this
> communication in error, you may not copy or distribute any part of it or
> otherwise disclose its contents to anyone. Please advise the sender of
> your incorrect receipt of this correspondence.
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/How-to-link-Oracle-attributes-to-SHAPEFILE-tp2731838p2732398.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
