[mapserver-users] How to link Oracle attributes to SHAPEFILE
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Tue Apr 28 09:19:07 EDT 2009
Hi list,
hum, could he use ogr vrt?
http://www.gdal.org/ogr/drv_vrt.html
2009/4/28 Paolo Corti <pcorti at gmail.com>
> > Hi Roald.
> > Thanks for the reply.
> > In this project, we are required to use SHAPEFILES and Oracle, so we
> can't
> > change this environment.
> > Roald de Wit wrote:
> >> Hi Pedro,
> >> A number of years ago i had a situation like you describe below. The
> >> solution we chose was:
> >> - Create a postgresql/postgis datawarehouse
> >> - Import shapefiles into postgis (shp2psql or ogr2ogr)
> >> - Import attribute info from oracle into postgresql (we needed a
> >> commercial license for converting Oracle to Postgresql)
> >> - Either create a view or merge tables to join the geometry and
> >> attribute info
> >> - Serve the lot through MapServer WFS/WMS
> >> I hope this helps.
> >> Regards, Roald
> Pedro, the solution Roald is proposing is IMHO the closest one you
> have to obtain what you need with MapServer (et alii).
> according to this doc: http://mapserver.org/mapfile/join.html
> supported formats are:
> * DBF/XBase files
> * CSV (comma delimited text file)
> * PostgreSQL and PostGIS tables
> * MySQL tables
> So you have 5 options:
> 1. shapefile + dbf (exported from Oracle tables)
> 2. PostGIS
> 3. MySQL
> 4. Oracle Spatial
> 5. Oracle + ArcSde
> in 2. and 3. no need to join, you could use views.
> in 4 you need views.
> with 5 there are many limits with joins, so could be the wrong way to go.
> Note anyway that for what you need (join to make thematic map)
> according to the above doc there is no way.
> So the only solutions to go are 3, 4
> I am not aware of other map web server software, neither OS or
> commercial, able to make mixed (from different sources) join for
> thematic mapping
> best regards
> Paolo
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090428/80025e03/attachment-0001.html
