[mapserver-users] PHP mapscript - QuerymapObj class
Worth Lutz
wal3 at mindspring.com
Tue Apr 28 09:48:32 EDT 2009
Yes, I saw the page you referenced. That was what prompted my question.
If you look in the documentation for the map object there is no reference to
the querymapobj-class. In other words there is no member which points to
the querymapobj and no method to get the object.
The reference map objects are gotten by a member pointing to the object and
the layer and class objects are gotten by a method. I was looking for a
similar member or method to get the querymapobj.
Have I overlooked something?
Thanks,
Worth
-----Original Message-----
From: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Sent: Tuesday, April 28, 2009 9:31 AM
To: Worth Lutz
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] PHP mapscript - QuerymapObj class
Worth Lutz wrote:
> Is there any way to access the QuerymapObj from PHP mapscript?
> I cannot find the reference to the object or a method to get to it in
> the MapObj class.
It should be accessible from the map object:
http://mapserver.org/mapscript/php/index.html#querymapobj-class
> Is the only way to change size or color in the mapfile if using PHP
> mapscript?
> Thanks in advance for your help,
> Worth Lutz
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
