[mapserver-users] PHP mapscript - QuerymapObj class
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Apr 28 10:08:30 EDT 2009
The member should be $oMap->querymap.
I will update the doc to reflect that.
Worth Lutz wrote:
> Yes, I saw the page you referenced. That was what prompted my question.
> If you look in the documentation for the map object there is no reference to
> the querymapobj-class. In other words there is no member which points to
> the querymapobj and no method to get the object.
> The reference map objects are gotten by a member pointing to the object and
> the layer and class objects are gotten by a method. I was looking for a
> similar member or method to get the querymapobj.
> Have I overlooked something?
> Thanks,
> Worth
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
> Sent: Tuesday, April 28, 2009 9:31 AM
> To: Worth Lutz
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] PHP mapscript - QuerymapObj class
> Worth Lutz wrote:
>> Is there any way to access the QuerymapObj from PHP mapscript?
>> I cannot find the reference to the object or a method to get to it in
>> the MapObj class.
> It should be accessible from the map object:
> http://mapserver.org/mapscript/php/index.html#querymapobj-class
>> Is the only way to change size or color in the mapfile if using PHP
>> mapscript?
>> Thanks in advance for your help,
>> Worth Lutz
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
