[mapserver-users] avl files
Till Adams
adams at terrestris.de
Wed Apr 29 02:55:36 EDT 2009
percy schrieb:
> give it fake directories as if you are using MS4W, then edit the
> mapfile it generates and substitute your linux paths...
> percy
> On 4/28/2009 1:43 PM, Paul Alarcon wrote:
>> Helllo is me again, i tried it but it ask me for a installed
>> mapserver on
>> windows and i use a linux server for mapserver, there is another
>> software
>> for make it for linux server ?
Dear Paul,
sorry, I'm the one who crimed Avein ages ago. I really forgot about that
software.
Avein is made for use in ArcView GIs 3.x only, so you'll need this piece
of software to run Avein. Undortunately Avein's last version goes on
Mapserver v4.2 or so, which should'nt matter, but there are no
opportunities for use of newer UMN functions.
Also AveiN! does not translate avl files, it is only made as an
interface between ArcViwew 3 projects and UMN.
A newer version for ArcGIS called Amein! was made 4 years ago, there you
can translate *some* of the symbols and patterns, but also not all. So
the way to go (if softwarei s there() might be to use ameiN1, to iport
the avl files into ArcGIs and try with that. Or forget about that and
you try on your own :-)
Regards,
Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
