[mapserver-users] Points and labels always together
Christy Nieman
cnieman at dmsolutions.ca
Wed Apr 29 08:16:45 EDT 2009
If you use an ANNOTATION layer instead of POINT, the only points that
will be drawn are those where the labels will be drawn.
Christy
Nelson Correia wrote:
> Hi all,
> Is it possible to have points and labels always drawn together when in
> a POINT layer? The objective is to draw localities on a map, and I
> don't want points or labels to appear alone.
> The problem is with LABELCACHE that when turned on, the points are all
> drawn, but only the labels that fit on the map will be drawn. This
> leads to some points without the correspondent labels. I think
> LABELCAHE turned off is not an option, because then the labels will be
> overlapped.
> Any ideas?
> Thanks,
> Nelson
> Get news, entertainment and everything you care about at Live.com.
> Check it out! <http://www.live.com/getstarted.aspx%20>
> mapserver-users at lists.osgeo.org
