[mapserver-users] avl files
Fischer, Brian
bfischer at houstoneng.com
Wed Apr 29 19:16:15 EDT 2009
There is an ArcMap extension that is going to be released by us later this summer that will essentially convert an ArcMap .mxd to a mapfile or GeoMOOSE app. So you could use ArcMap if you have it to import your .avl symbology and then export it to a mapfie. We are not sure at this point if the software will be open source or sold at small shareware cost for the extension.
Brian Fischer
Houston Engineering, Inc.
763-493-4522
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Till Adams
Sent: Wednesday, April 29, 2009 1:56 AM
Cc: MapServer; Paul Alarcon
Subject: Re: [mapserver-users] avl files
percy schrieb:
> give it fake directories as if you are using MS4W, then edit the
> mapfile it generates and substitute your linux paths...
> percy
> On 4/28/2009 1:43 PM, Paul Alarcon wrote:
>> Helllo is me again, i tried it but it ask me for a installed
>> mapserver on
>> windows and i use a linux server for mapserver, there is another
>> software
>> for make it for linux server ?
Dear Paul,
sorry, I'm the one who crimed Avein ages ago. I really forgot about that
software.
Avein is made for use in ArcView GIs 3.x only, so you'll need this piece
of software to run Avein. Undortunately Avein's last version goes on
Mapserver v4.2 or so, which should'nt matter, but there are no
opportunities for use of newer UMN functions.
Also AveiN! does not translate avl files, it is only made as an
interface between ArcViwew 3 projects and UMN.
A newer version for ArcGIS called Amein! was made 4 years ago, there you
can translate *some* of the symbols and patterns, but also not all. So
the way to go (if softwarei s there() might be to use ameiN1, to iport
the avl files into ArcGIs and try with that. Or forget about that and
you try on your own :-)
Regards,
Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
