[mapserver-users] Mapserver 5.4 & SYMBOLSET
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Apr 29 23:13:49 EDT 2009
Can you share your symbolset file? I've not had an issue with that change.
Steve
>>> David Nugent <davidn at datalinktech.com.au> 04/29/09 9:54 PM >>>
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello all,
I've recently upgraded to mapserver 5.4 and hit a problem with
SYMBOLSET.
It seems that a file containing symbols referenced from the .map file
must now contain a SYMBOLSET keyword at the start (and presumably end
with END?). I made this change, but the parser still complains with
the message "First token must be SYMBOLSET".
Not really wanting to waste time on debugging the lex code, I simply
removed the check that emits this error from mapsymbol.c and all works
as expected. Obviously there is a deeper problem, whether it be the
logic in that statement (which appears to be correct as far as I can
tell) or the lex parser itself.
I'm just wondering if anyone else had hit the same problem.
Regards,
David
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (Darwin)
iEYEARECAAYFAkn5EkgACgkQgyBtWyGDJqUwLwCcDdlZ1p/DUyTJ8/A9aOU8U6p1
c24AnjMwiSaNwPPQhDay/V3pTu1OnDtQ
=pUQC
-----END PGP SIGNATURE-----
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
