[mapserver-users] Mapserver 5.4 & SYMBOLSET
    Guillaume Sueur
    no-reply at neogeo-online.net
    Thu Apr 30 08:25:10 PDT 2009
Good to know !
Thanks !
Christy Nieman a écrit :
> Hi,
> It was addressing some potential security problems:
> http://lists.osgeo.org/pipermail/mapserver-users/2009-March/060600.html
> Christy
> Guillaume Sueur wrote:
>> Hi,
>> I think what David meant was about getting an error when SYMBOLSET is
>> not declared in the symbol file since 5.4.
>> I ran into the same problem, and had to add SYMBOLSET ... END to my
>> symbol files to have them running fine with MapServer 5.4.
>> Is it something newly added, or just a long lasting requisite become
>> mandatory ?
>> Regards,
>> Guillaume
>> Daniel Morissette a écrit :
>>> Are you sure that the file you are editing is really the one used by
>>> your mapfile? That's a common mistake... to verify that, try inserting
>>> an invalid keyword in place of the SYMBOLSET keyword in your file and
>>> verify that MapServer produces a parser error about it. If it doesn't
>>> then it's probably not using the file you think it is.
>>> Daniel
>>> David Nugent wrote:
>>> It starts (and ends) like this:
>>> SYMBOLSET
>>>   SYMBOL
>>>         NAME    "point"
>>>         TYPE    ELLIPSE
>>>         POINTS
>>>                 1 1
>>>         END
>>>         FILLED  TRUE
>>>   END
>>>   SYMBOL
>>>         NAME    "dashed"
>>>         TYPE    ELLIPSE
>>>         POINTS
>>>                 1 1
>>>         END
>>>         FILLED  TRUE
>>>         STYLE
>>>                 8 6 8 6
>>>         END
>>>   END
>>> END
>>> Regards,
>>> David
>>> On 30/04/2009, at 1:13 PM, Steve Lime wrote:
>>>>>> Can you share your symbolset file? I've not had an issue with that
>>>>>> change.
>>>>>> Steve
>>>>>>>>> David Nugent <davidn at datalinktech.com.au> 04/29/09 9:54 PM >>>
>>>>>> Hello all,
>>>>>> I've recently upgraded to mapserver 5.4 and hit a problem with
>>>>>> SYMBOLSET.
>>>>>> It seems that a file containing symbols referenced from the .map file
>>>>>> must now contain a SYMBOLSET keyword at the start (and presumably end
>>>>>> with END?). I made this change, but the parser still complains with
>>>>>> the message "First token must be SYMBOLSET".
>>>>>> Not really wanting to waste time on debugging the lex code, I simply
>>>>>> removed the check that emits this error from mapsymbol.c and all
>>>>>> works
>>>>>> as expected. Obviously there is a deeper problem, whether it be the
>>>>>> logic in that statement (which appears to be correct as far as I can
>>>>>> tell) or the lex parser itself.
>>>>>> I'm just wondering if anyone else had hit the same problem.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
