[mapserver-users] Unexpected behavior of wfs layer using postgis
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Fri Aug 7 07:52:43 EDT 2009
Hi list,
I have a wfs layer (data stored at postgis) and that layer have a complex
data statement
mapfile
-----------xxxxxxxxxxxx-------
LISTCOIID - cgi param
#LAYER WFS PARCEL
LAYER
NAME 'parcels'
#DEBUG 5
METADATA
"wfs_title" "parcels"
"wfs_request_method" "get"
"wfs_service" "wfs"
"gml_featureid" "id"
"gml_include_items" "all"
"wfs_encoding" "UTF8"
END
TYPE POLYGON
STATUS ON
DUMP TRUE
CONNECTIONTYPE postgis
CONNECTION "host=localhost user='postgres' password=postgres_password
dbname='wfs_server'"
DATA "the_geom FROM (select distinct parcel.id,parcel.the_geom from
mapserver_parcels parcel where parcel.parcelid in( SELECT distinct
col.idFROM college col WHERE col.date_exclude IS NULL AND
((%LISTCOIID% =
col.id) OR (SELECT count(*) FROM perm_group_item pagi, visual colv ,
perm_group pag, perm_acess pa WHERE pagi.date_exclude is null AND
pag.date_exclude is null AND colv.date_exclude is null AND pa.date_exclude
is null AND colv.perm_group_FK = pagi.perm_group_fk AND pagi.perm_group_fk =
pag.id AND pag.date_exclude IS NULL AND pagi.perm_acess_fk = pa.id AND
pa.name = 'Test1' AND colv.org_interference_fk = %LISTCOIID% AND
colv.org_interference_fk_fk = col.id) > 0))) as foo USING UNIQUE id USING
SRID=4326"
#PROCESSING "CLOSE_CONNECTION=DEFER"
PROJECTION
'init=epsg:4326'
# "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
END
CLASS
NAME 'parcels'
STYLE
SYMBOL 0
SIZE 10
OUTLINECOLOR 0 0 0
COLOR 150 123 90
END
END
END
------------xxxxxxxxxxxxx----------------
when i activated the postgres log, i notice a strange, don't expected
behavior. Mapserver changes the query (the data statement) and refactory in
4(four) other queries:
query 1:
select
encode(AsBinary(force_collection(force_2d("the_geom")),'NDR'),'base64') as
geom,"id" from (select distinct parcel.id,parcel.the_geom from
mapserver_parcels parcel where parcel.parcelid in(SELECT distinct
col.idFROM college col WHERE col.date_exclude IS NULL AND ((25 =
is null AND colv.perm_group_FK = pagi.perm_group_ AND pagi.perm_group_ =
pag.id AND pag.date_exclude IS NULL AND colv.perm_group_FK =
pagi.perm_group_ AND pagi.perm_group_ = pag.id AND pag.date_exclude IS NULL
AND pagi.perm_acess_fk = pa.id AND pa.name = org_interference_fk AND
colv.org_interference_fk = 25 AND colv.org_interference_fk_fk = col.id) >
0))) as foo where the_geom && GeomFromText('POLYGON((-48.05 -15.77,-48.05
-15.71,-47.85 -15.71,-47.85 -15.77,-48.05 -15.77))',4326)
query 2:
select * from (select distinct parcel.id,parcel.the_geom from
pa.name = org_interference_fk AND colv.org_interference_fk = 25 AND
colv.org_interference_fk_fk = col.id) > 0))) as foo where false limit 0
query 3:
select
"id",encode(AsBinary(force_collection(force_2d("the_geom")),'NDR'),'base64')
as geom,"id" from (select distinct parcel.id,parcel.the_geom from
colv.org_interference_fk_fk = col.id) > 0))) as foo where "id" = 245
query 4:
select
colv.org_interference_fk_fk = col.id) > 0))) as foo where "id" = 246
query 5
select
colv.org_interference_fk_fk = col.id) > 0))) as foo where "id" = 247
------------xxxxxxxxxxxxxx----------------
the wfs layer are returning 3 geometries (that is the expected result) but i
don't understand why mapserver is generating this four queries.
the first query (query 1) returns the id column (pk on my table) and
the_geom (geometry column).
the second query (query 2) don't return nothing.
the third query (query 3) return the first id and the first the_geom values
(query 1 already did that).
the forth query (query 4) return the second id and the second the_geom
values (query 1 already did that).
the fifth query (query 5) return the third id and the third the_geom values
Aproximated times:
query 1: 3s
query 2: 18ms
query 3: 2.6s
query 4: 2.5s
query 5: 2.7s
The problem with this extra-queries is that they consume time so the query
uses 8 seconds to bring back the information when should use 3 seconds to
brinq back information.
This refactory of the queries made by mapserver is alright or this is a bug?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090807/be4d38a0/attachment-0001.html
