[mapserver-users] Problem using getShape with MsSql2008
(Mapscript C#)
Tamas Szekeres
szekerest at gmail.com
Fri Aug 7 10:21:04 EDT 2009
This appears to be a null shape with no valid geometry. (type=3, numlines =
0)
Best regards,
Tamas
2009/8/7 Paul james <pauljame at gmail.com>
> The layer geometry is fine...
> I´m sending a shape property screenshot...
> Paul
> On Fri, Aug 7, 2009 at 5:25 AM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Paul,
>> There is a function (find_bounds) calculating the bounds in mapmssql2008.c
>> which should provide correct results.
>> Could you check whether the returned geometry is correct by dumping the
>> point coordinates of each lines in mapscript?
>> Best regards,
>> Tamas
>> 2009/8/6 Paul james <pauljame at gmail.com>
>> Just an update...
>>> The shape values are all there... The only thing is wrong is the bounds
>>> (-1) ...
>>> On Wed, Aug 5, 2009 at 5:44 PM, Paul james <pauljame at gmail.com> wrote:
>>>> I´ll check...
>>>> But the same layer/id worked fine using Postgis... So I should be a
>>>> bug...
>>>> Paul
>>>> On Wed, Aug 5, 2009 at 5:38 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>> Hi,
>>>>> I think you should check the sql statement submitted by the driver by
>>>>> using the SQL Profiler. I suspect no records have been retrieved during the
>>>>> fetch.
>>>>> Best regards,
>>>>> Tamas
>>>>> 2009/8/5 Paul james <pauljame at gmail.com>
>>>>>> Hello guys...
>>>>>> That code is working fine with Postgis:
>>>>>> _layer.open();
>>>>>> var _shape = new shapeObj((int)_layer.type);
>>>>>> _layer.getShape(_shape, 0, __id.ToInt32());
>>>>>> The _shape.bounds are all -1 using MsSql2008 ...
>>>>>> Any idea?
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090807/78e4829d/attachment-0001.html
